*ERROR in nonlingeo: max. # of increments reached
I run the attached input and it fails around the 20s mark regardless of the timestepping with the error in the title. Anyone got any ideas?
Frank
  • I have found that if I change the modulus to 1Pa, the solver will go longer...up to around 120s before failing with the same error.
  • CCX sometimes fails such large rotations at specific angles. You can work around it by altering the time step from 2 s to say 2.1 s and it seems to avoid whatever problem it got stuck on.
