Geommetry preparation capabilities in Mecway
I am new on the forum, recently I acquired a license, nice to meet this so active comunity. I have a step model imported, and I want to do some modifications (division of some surfaces, or to move some corners nodes, for example). Is it possible to do on Mecway, or I have to go to the CAD software and make changes there and export them?
On the other hand, I apreciate some recomendations for the next issues I want to take into account in my model (bolted connection modeled by surface elements):
1- Sloted holes. How can I define the behaviour of these holes properly? Is there a way to define a constraint between two nodes to simulate that type of behaviour?
2- I have some parts welded. I am thinking about avoid modeling the welds, and then get the internal forces in nodes and make verifications. How can I do this?
3- How I define the contact between surfaces? Shall I have to separate the same distance than the thickness of the plates?
Finally, I have read that Openradioss can perform Implicit analysis. How I can define this in Mecway?
Thank you very much.
JJJ
JJJ
There are several ways to approach the slot arrangement. I have used contact in this example -it may also give you some ideas on how to deal with contact.
An parts can be only moved?
On the other hand, about sloted holes, the approach you propose is modeling everything with solid elements. I was thinking about modeling with shell elements, and bolts by beam elements.
Thank you very much!
