dynamic response on steel frame
Hi everyone,
I have designed a steel frame using spectrum analysis for seismic hazard.
I have made the same analysis using ROBOT.
On the classic ULS (wind, snow, DL) I have very close results between my MECWAY model and ROBOT.
But for dynamic design beam forces increase by twice (for example bending moment on top of the columns Mw (MECWAY = 136748Nm // ROBOT My = 56815Nm)
Spend a lot of time to understand what's going on here my results:
->reactions are the same
->mode shapes and frequency are the same
I wonder if on MECWAY dynamic dynamic response there's something that I had misunderstood.
I'm not sure that rotationnal mass inertia which can be controled on an accurate solver in ROBOT make so much impact on MECWAY model.
Hope there's something easy that is out of my sight.
Here's the model.
Best regards.
Sofien
Here's the model.
Best regards.
Sofien
Based on this:
->reactions are the same (I assume you mean in the static solution)
I can only think that you are using a larger number of modes for the modal superposition which would include more mass into the solution. ¿Did you check in Robot how many modes are considered compared to Mecway and how many mass is movilized on each solver?
I would also check if Robot might be constraining the torsional modes.
Same modes number (50)
as you can see there's only 40.42% of the Z mass fraction that have been taken into consideration on ROBOT model but without the MECWAY dynamic results (see below) we will not be able to conclude.
Actually it's not possible to extract the same results from MECWAY models because of beam-release or contraint equation there several on my model.
I think that ROBOT have an accurate solver which filter torsionnal modes (you can switch it) but I will be suprised that it's the only reason of such a gap on the bending moment.
I don't have any clue.
Best Regards.
Sofien
My general opinion, I would not trust structural softwares (Staadpro, Robot, spacegass etc…). The caliber of people coding those software packages is really poor, almost all the time they implement simplifications which aren’t followed by other software vendors which develop pure FEA software
(Ps I haven’t looked at any of the results as yet)
Regards.
Sofien
Commercial code have been developed for more than 30 years by pro devs for some of them... There are widely used by people who had a full trust of the efficiency of their software which it's cost a lot to buy and upgrade every year.
There is few people who goes deeper with the commercial software deeper and I agree with you there is some simplification taken by devs (for example U shape, or torsion loading in accordance with EC3 standards)
Anyway I bet that I am wrong with my MW model and ROBOT provide the correct results.
I am going to play the same studies with RSTAB v9 to clear my mind.
If you have an idea it should be great.
Best regards.
Sofien
@sofien_73
That should be under solution/MechanicalMisc/Modal effective Mass and Modal effective Mass fraction for a frequency analisys. I haven't tested on your problem so I don't know if there could be some limitation due to your actual set up.
Maybe it could be fixed for the next version of MECWAY.
BR
Sofien
Mecway's beams do have torsional rotational inertia, so is that turned on in Robot?
Or are you asking me to suppress all MPC?
For torsionnal masses I am speaking about modal analysis, ROBOT can suppress/avoid torsionnal modes which may have an impact on the global response of the structure.
But I am not sure that torsionnal mode may increase by more twice the bending moment on the head of the columns.
BR
Sofien
I think that doing elastic spectrum test shoud induce considerably worst results.
BR
Sofien
Below an example of stacked rack.
Here's the results:
bending moment on the top of the columns (the same as before):
MW 23929Nm
ROBOT 13494Nm
for the modal analysis you can open the Excel table attached.
There are big difference with the frequency and %masses excited.
I also have watched the modal shape in MECWAY we have a lot of torsion modes which have been ignored by ROBOT modal analysis solver.
Columns warping along it's own axis... same for some beams it's not physical.
I am going to make the same design with RSTAB v9.
Anyway, for steel frame design it have to be fixed. ie we should have the possibility to exit torsion mode for dynamic analysis.
and there is some other things that should be improved:
-Nodal reaction not avaible for dynamic response 3d
-we can't perform axial release (u,v,w) only rotationnal for beam not oriented in accordance with global coordinate system (X,Y,Z) which is not an option for us.
-Modal results not avaible for MPC, I really need MPC for steel frame design.
BR
Sofien
There is some specific connections and gusset that will be step out of the analysis, if it's ok for you go for beam analysis.
is it anchored ?
BR
Sofien
Depending on the type of profile, could be necessary an specific type of analysis; I mean, if the structure is designed with open cold formed profiles, you should analyse by the finite strip method.
However, I'm concerned about any possible bugs so I do hope to somehow identify the cause of this difference.
>without any MPC and no local masses and only merged nodes full embeded columns fixation on MECWAY and ROBOT.
Before removing those features the modes were the same in Mecway as ROBOT but after the change they're different. Is that right? That sounds like it might be a 2nd different issue. Still keep removing features or mesh until they agree. If you get down to just one beam element and they're still different, it should be easy to identify why.
I agree with you. Let's be honest I have too much ambition for a general FEA software which is effective for the scope it have been design for (and costless).
There's no bugs on MECWAY.
We can't compare specialized steel frame structure design software with optimized methods and solver (ROBOT STRUCTURAL ANALYSIS).
The comparaison have no sense.
Anyway, I've made a small model a cantilever columns with the same spectrum analysis.
I have obtained the same gap with Mw and Qv average increasing by twice.
So I think that it's just the optimized ROBOT solver which exclude non physical mode (especially torsion or small displacements modes).
I don't need to go deeper at this time.
Thanks a lot.
BR
Sofien
