non linear shell case
Hi everyone, I'm looking for tips to push a classic case of a shell which has it's four sides simply supported and submited to pressure to the collapsing. Non linear analysis is not enough to do this (equivalent plastic deformation over 12% is the higest limit for this kind of analysis with steel plate) maybe there's somebody who had made this kind of analysis with realistic failure criteria with openradioss.
Here the model for example.
BR
BR
Page 4/53.
Authors. Biswajit Banerjee[1]
Jeremy Chen, Raj Das, Anjukan Kathirgamanathan
https://www.researchgate.net/publication/258848858_Comparison_of_ANSYS_elements_SHELL181_and_SOLSH190
Use symmetry BC and reduced integration S8R.
That is to start assuring the right BC and minimum number of elements.
Then you can switch to Plasticity (
Disla, what is the next step the main objective is to evaluate failure pressure in accordance with real material curve which I don't have. Is it possible to use failure criteria with non linear analysis we can only simulate elastic and plastic domain I just watched for equivalent plastic strain but it goes higher than 100% which have no physical sens but it's ok because we don't have any failure criteria computed.
1. Boundary conditions
A model intended to reproduce the real behaviour of a component can rarely be considered genuinely simply supported. Although this boundary condition is widely used for theoretical verification and benchmark problems, it is difficult to reproduce accurately in a physical system.
Constraining displacement in the z-direction does more than prevent the plate from moving downward or “falling” through the support. It also prevents any local separation or uplift within the constrained region. In this particular case, allowing the corners to lift off the supports appears to produce a significant difference in the structural response.
A contact formulation that permits separation while preventing penetration may therefore represent the actual support conditions more realistically.
2. Definition of the applied load
The physical origin of the applied pressure should also be clearly defined. Pressure is a distributed load acting normal to the current surface, and its direction may change as the plate deforms. This is relevant for a finite, initially flat plate with an unconstrained perimeter, since a follower-pressure load will tend to promote a curved or dome-shaped deformation.
It would therefore be useful to clarify what physical mechanism generates the load and how it is applied at the plate boundaries. Depending on the actual loading arrangement, the model may be subjected to a prescribed surface traction rather than a true pressure load. The distinction is important, particularly in a geometrically nonlinear analysis, because pressure and fixed-direction traction do not generally produce the same response.
Look for NAFEMS Benchmark Challenge Number 2. Assessment of a Simply Supported Plate with Uniformly Distributed Load. I referenced it above. Read about the different Engineers approach to this subject , different element types limitations and complexity of reproducing simply supported BC condition for 3D elements.
With a quick search you will realize how much debate there has been arround your problem.
This is a free access webpage containing reference values:
https://www.esrd.com/resource-library/product/nafems-benchmark-problem-02-solution/
