Meshing problem
Solid models of a web and separate flanges - exported as STEP - imported into Mercway
When meshing, I receive a series of error messages.
divide edge: local h too small
CORRECTED
can someine assist as I cannot resolve the meaning at this time
  • Can you share the geometry file?
  • Those messages from the mesher can be misleading and I don't know what they mean. Some that look like yours are normal and harmless.
    It sounds like you have multiple parts which often won't mesh. Use File -> Split step assembly then import the individual part files it generates.
    Or it could be not water-tight. You can try a surface mesh then if that works, use View -> Show model edges and/or View -> Open cracks to try to find any gaps between surfaces. Or it might not be a single part.
