Managing solid geometry
Hi Guys
With regard to the use of surface geometry it is pretty easy to modify thicknesses to perform iterations on designs.
However, when it comes to solid geometry, how are you guys managing the models?
Say there is a plate and the thickness needs to be increased, since Mecway does not link to a modelling interface directly (like Discovery from Ansys) you need to modify this on your CAD model and then basically rebuild a new model. Have I lost the plot or is there an easier way to manage this?
If you have added faces or deleted features, then the algorithm for STEP file export in your CAD program may define the faces in a different order than before, so then you have to reselect the faces for boundary conditions and loads after importing the STEP file to Mecway.
