Model with screw pre tension
Hi all,
I'm working on a model which I've stepped through and tested up until I need to test the tightening of the screws. As soon as I add the pre tension it falls over.
I've tried using the same screw model in a simple test and it seemed to be fine, so I'm wondering if there is something somewhere I'm missing, or over complicated it.
Wondering if someone could take a look at it and see if anything jumps out at them?
The model is sensitive so I'm not totally sure how I'd go about sharing it on here?
Cheers
Cheers
The difference I see in this model is the threaded hole is made bigger than the screw, is this generally a requirement?
For the force control case, if you select the surface of the plate attached to the bolt head, and assign it an Elastic Support value of 0.1 and 0.1, you'll find it runs all the way through but the plate flies up a bit - because the bolt load has been overcome.
My workflow:
1) appliy the expected/desired pretension as a force
2) run the sim with the pretension only, no other loads
3) measure the shortening of the bolt cause by the pretenstion foce where mecway "cuts" the bolt
4) apply the measured distance as lenth a justment for the "real" simulation run.
