Union/Fuse Part Separated when Import in v36
Victor,
Do we have an option to not separate union/fuse part when importing in v36? We don't have this issue in v34. Please see attached.
  • Sorry about that. There isn't a switch to change it so perhaps stay on 34 or only open existing liml files created from 34 or earlier. I should get it working in v37 due in early December.
    To be honest, I didn't know Netgen could mesh separate surface bodies and joint them properly like that! I think the fix will probably be keeping multi-body parts as a single geometry item/component as before, possibly with a switch to change to this separate item behavior.
  • Thank you!
  • if the goal is to achieve a "fused" single part mesh,
    then MW36 can do that already
    -setup a mesh parameters for one body
    -copy parameters to all bodies
    -mesh the whole folded
    -select all parts in the components and material and simple merge nearby nodes
    for my normal work flow this has the advantage of keeping components in their own folder so that different materials can be added to each
  • I am aware of those steps but not what I would like to do if not needed.
  • Thank you for the comments.
