Union/Fuse Part Separated when Import in v36
Victor,
Do we have an option to not separate union/fuse part when importing in v36? We don't have this issue in v34. Please see attached.
To be honest, I didn't know Netgen could mesh separate surface bodies and joint them properly like that! I think the fix will probably be keeping multi-body parts as a single geometry item/component as before, possibly with a switch to change to this separate item behavior.
then MW36 can do that already
-setup a mesh parameters for one body
-copy parameters to all bodies
-mesh the whole folded
-select all parts in the components and material and simple merge nearby nodes
for my normal work flow this has the advantage of keeping components in their own folder so that different materials can be added to each
