Contact stiffness approximation
Hi Guys
I come from a Strand7 background which uses a very different formulation for contact compared to CCX. What is the easiest way to estimate the contact stiffness in a model?
Something like K = E/H where H would possibly the average length of an element...
Have you take a look at Mortar contact?. I have obtain clearanes of 1E-35 with reasonable times. There is some limitations due to units conversion but results are really good when it works.
No, I did not know about that, but I will definitely look into it as 1E-35 is approximately zero for all intents and purposes, so it would definitely help me better aproximate the contacts of gear faces. I'll try that out soon and see what can be concluded from it.
I have modified keyword *contact pair to TYPE=MORTAR and the .INP file say so too, but the solver just exits without any error or message that lets me know why
Do you have an example of an analysis where you succesfully used the Mortar contact, or can you help me find out what I did wrong?
If the solver just exits without any error or message you are probably facing a reported ccx Bug. Check:
https://github.com/Dhondtguido/CalculiX/issues/162
If that's the case try scaling your model x100 as first check. If solvers runs after scaling you need to rewrite your model base on Units (mm, ton, s, °C) and run it outside Mecway to avoid the automatic conversion to m, Kg.
Let me know if that worked. It would also be a second confirmation of the bug existance.
NOTE: I don't discard someone worked on that issue according to the github Logbook. Maybe you could compile last available version to see if that was fixed.
I am not sure how to do the rewriting into a different unit system and running outside of Mecway and compiling calculix off of github is also something that I have never done before...
In my case: ccx_MKL.exe -i MyFileName.inp
I can’t help with compilation of a ccx version under construction sorry. Never did that.
Because scaling those two things and running it in Mecway is easy and it runs.
Or am I missing something obvious here?
For example when scaling by factor 2, surface area will scale with 2^2 and bending stiffnes of a beam will scale with 2^4 (b*h^3)/12.
However, it may not matter afterall because the runtime with mortar contact is unacceptably long. I am ramping my load during one second and are then rotating the output gear one degree per second for an additional 17 seconds, so the total simulation time is 18 seconds.
With 100K GPa/m penalty stiffness, the runtime is 4h 20 minutes.
With 500K GPa/m penalty stiffness, the runtime is 4h 50 minutes.
With mortar contact, It has only converged 2 timesteps and are at time 0,2s after 2h 10min runtime.
I usually have all of my teeth contact faces in one contact assignment but I also tried one contact assignment per tooth pair and it is the same situation of 0,2s after over 2h runtime.
I will try with a coarser mesh at some point but I am not sure it will be fruitful as I need a fine mesh in the contacting faces to be able to see the contact line and read out a believable contact pressure. If the contact line is narrower than the element size, I have observed (with penalty based contact) that the contact line is broken/discontinuous and that the max concact pressure is higher and is usually just next to an element that is outside of the contact line and thus has a very low contact pressure.
I will however have to iterate the design with penalty based contacts for a bit so I have something for the customer.
